Network Management
wlanESSID not-accessible
[ Edited ]
Hi, I'm trying to get this objects in order to graph them in Cacti, but I can't get access.
I need to graph NumStations per SSID, I can get the second object but not having luck with the first one.
Is it there any way to get that objects? Why are they not-accessible?
P.S. : Tried versions:
  • AOS-W (Model: OAW-4304) v. 5.0.4.14
  • AOS-W (Model: OAW-4550) v. 6.4.3.4
Re: wlanESSID not-accessible
I am precisely with the same problem, I want the ESSID and the number of connected stations...
Curious, if I select "Table View" in the Mib Browser, on  wlsxWlanESSIDEntry, it shows the ESSID of WLANs...
Any tip?
