Norsk Forum
CCPM join with AD
Getting the below error while joining CCPM with AD.
Request help us to resolve the issue.
Adding host to AD.in domain...
INFO - Fetched REALM 'AD' from domain FQDN 'ad.iith.ac.in'
INFO - Fetched the NETBIOS name 'AD'
INFO - Creating domain directories for 'AD'
Enter iithydadmn's password:
Failed to join domain: failed to lookup DC info for domain
'AD.in' over rpc: Logon failure
INFO - Restoring smb configuration
INFO - Restoring krb5 configuration file
INFO - Deleting domain directories for 'AD'
ERROR - CPPM failed to join the domain AD.in with domain
controller as ad.in
Join domain failed
Thanks and regards,
Ashok
Re: CCPM join with AD
Are you using DNS servers that can resolve your domain controllers FQDN?
Also try using a different administrator account to add CPPM to the domain.
Cheers
James
