Norsk Forum
Need help?
Hello all,
I would understand how the upgrade with airwave work?
All the cluster is down ? or the upgrade is one per one ?
The wifi network continues to work ? there are a roaming to ensure the continuity ?
I have 30 IAP per cluster, how long do you think it take ?
Thank you,
Regard
