Frequent Contributor I
Ap-104
Can I connect an AP-104 with a Cisco Yugi antenna? I have the adapter for the antenna cable to the AP. Also, is there any setting I have to set in my controller to adjust for this antenna? I connected everything above but it doesn't seem I'm getting a signal out of the antenna. The Antenna did work with a Cisco AP-1235 but we are in the process of switching to Aruba APs..
Re: Ap-104
We are only allowed to deploy by the FCC access points with antennas that we have sold and tested together.
Re: Ap-104
So your telling me an Aruba AP can only use Aruba antennas?
Re: Ap-104
I'm sure you can get it to work; it is just not supported. You would need to put in the DB for each antenna in the AP provisioning screen otherwise the AP will not broadcast.
Re: Ap-104
It can work with other manufacturers' antennas, but would no longer be FCC certified as a complete system. From a legal perspective, you would need an FCC certified installer to validate the system.
It's not a technical limitation, but a legal/regulatory one.
Charlie Clemmer
Aruba Customer Engineering
Re: Ap-104
I understand now.. I actually meant an AP-124 not AP-104.
Re: Ap-104
Yes, what he said :)
Re: Ap-104
OK, so I can't use the Cisco Yagi 13.5 dBi Antenna with the N-type of connector. Any recommendations for a similar Aruba Antenna with a N-type of connection? It will be used with a AP-124 but I do have the coupler need for connection to the AP.
Aruba
Re: Ap-104
Which Frequency band is supported on the existing deployment? Is it 2.4, 5.0 GHz, or both ?
Re: Ap-104
2.4 Ghz.. not really looking for 5 Ghz. We're just trying to cover a grassy area at the University that the students can sit on chairs while using their laptop. The Cisco 1232 with the Yagi antenna worked great. This is the only area I'm having trouble covering. We currently have a 5 meter cable between the antenna and AP. Moving the AP closer to the antenna isn't an option..
