Outdoor & Mesh Networks
Occasional Contributor I
Ap 175 Grounding
Should I use ground connections of AP for outdoor projects. Is it vital to use ground connection on AP. And, does it affect the antenna performance or efficiency? (Antenna is AP-ANT-90)(ap-175)
Moderator
Ground connection is required
The ground connection is critical to protect the AP from damage by induced transients and is a safety (UL) requirement for installation of outdoor products.
It is always required to be connected to keep warranty valid.
The RF performance is probably not so much an issue.
