Outdoor & Mesh Networks
MVP
Mesh node not showing up in Controller.
I have never seen this before and I am wondering if anyone else has come across this and if you have a fix.
At one of my sites, I have a Portal serving a Point. On the other end of the point I have a switch with cameras connected. The point disappeared from the controller. I am still able to ping the Point, Switch, and cameras.
Any way to get the Point to appear back in the controller?
Sean Rynearson
Re: Mesh node not showing up in Controller.
type "show AP mesh topology" on the controller to see if it is recognized....
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
MVP
lol already done that. No it does not show up. The funny thing is that everything on the otherside of the link is reachable.
Sean Rynearson
See if the point is under unprovisioned access points, which would mean it is in recovery mode.
MVP
Yeah, I was hoping it would eventually appear there but it hasn't. All in all the point is working perfectly, it just is not showing up in any controller lol.
Sean Rynearson
What version of code? 5.0.3.3? Do you have old logs that have the ipaddress of the point, and do you see it in the controller's datapath table?
show datapath session table
Jerrod Howard
MVP
Yes 5.0.3.3. All is good now. After the weekend, All points are up.
Still do not know why and airwave isnt saying anything.
Sean Rynearson
Would this happen to be a master-local with the mesh APs terminated on the local? Or is this a single controller?
Jerrod Howard
