Outdoor & Mesh Networks
Occasional Contributor I
Msr2000 point-to-point deployment performances
Dear,
I installed a point-to-point link with Msr2000 in 2.4 Ghz with 2x2-2714 antenas, the regulation domain is set to Europe, the max power in this domain is 16 dbm. the distance between the two building is 750 m. I want know wthat the max distance i can get with this configuration.
Re: Msr2000 point-to-point deployment performances
Aghiles,
Looks like you posted two different threads about the same problem.  Please see my response to your other message.
-cl
