Remote Networking
2 Remote Access Points on a site
Hi!
What is the best way to deploy two Remote Access Points without a controller. I have come up with three alternatives
1. 2 separate RAP
2. One RAP and one Campus AP which set up a gre tunnel within the IPSEC
3. Remote Mesh
I see some limitations to these implementations like roaming.
does anyone have a good solution for this?
IIRC, tunneling an AP through a RAP is not supported.
Probably your best supported method would be a RAP-5 and 2x IAP-105. Use the Aruba Instant 105 model to create your WLAN at this remote site (standalone). Use the RAP-5 to tunnel traffic back. This is the only solution I can think of without using a controller as a remote node or multiple RAPs.
Zach
Zach Jennings
Re: 2 Remote Access Points on a site
Zach
+1 on the unsupported.
Thanks for the reply. I understand that a campus AP tunneled through a RAP is not supported, with one ore two AP.
Do we have a supported method?
Your first option, 2 separate rap is probably the best way. Make sure that both are tunneling the traffic back to the controller on that SSID.
Thank you for prompt reply.
Will we have roaming between the two devices?
If the Virtual AP that you have deployed is in tunnel mode, yes.
Contributor I
So to be clear.... :confused:
deploying multiple RAPs (most likely RAP5s) in tunnel mode at a single site (within wifi range of each other) is supported for data (might also include MS Lync traffic), wifi voice, or both?
thanks
Vinson
Latency-sensitive peer to peer traffic could be a challenge in that scenario depending on the latency, but other data traffic should be fine.
