620 Controller as VPN
Hi All,
I am using a 620 Controller as our VPN terminator and possibly the RAP2's. I noticed the firewall throughput not that high for AES or 3DES but how many people do you think I cold fit on there concurrent surfing and few internal pages and some email and downloading some files every now and then.
Luke
Re: 620 Controller as VPN
That is also be a function of your incoming and outgoing bandwidth, which will be shared among all users, as well as the infrastructure at the headend.
