Remote Networking
Add RAP / Modify whitelist via CLI
For some reason I am not seeing a lot of the RAP's I've whitelisted via the web console. If I try to add one that I've added before it says that I've added it already.
How do I show the AP white list and how do I modify? I cannot find this info (yet) in the guides.
A search for whitelist on the aruba knowledgebase and command guide come up with 0 results.
Re: Add RAP / Modify whitelist via CLI
I believe that was an issue in RN 3.0 when displaying on the WebUI, upgrading to 3.1 should fix that issue. You should also be able to get a complete display from the CLI using 'show local-userdb-ap'
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Thank you!!! Very good. I can't wait to upgrade mine. Thanks again, life saver. ;)
