Remote Networking
Frequent Contributor II
Aruba 3400 - Aruba 620 _ remote node controller or master-local config???
i see in 6.0.x there's a new feature called remote node controller.
i've a 3400 in Main office and 620 in at branch office.
Previously i thought to make a Master-Local config (ipsec tunnel built on controller permit me to have the same config on both site so customer laptot have not to change their config.)
I use 802.1x auth config for my laptop.
i've read manual and it seems that "remote node controller" is only a CLI config, there's no web UI to configure (only Remote node wizard on 620).
Remote Node is better than Master-Local only for licensing and easy provision??
there's config limitation on Remote node?
on local in Master-local envirorment i've only to change few parameters but quite all config is taken from master... in remote node controller i've to make a new config that will be pushed to remote node... it doesn't seem very easy to manage..
Regards
Andrea Consadori.
Andrea Consadori
ACMP 5.0 and 6.3
Re: Aruba 3400 - Aruba 620 _ remote node controller or master-local config???
According to the release notes, the remote node functionality in 6.2.2.1 is beta quality for now and it might not meet your needs. Please do not deploy it in a production network, for now.
ok thanks, i will use master-local and i'll read future release notes.
Andrea Consadori
ACMP 5.0 and 6.3
JYL
is the remote node still in beta quality on 6.1.2.3?
thanks
J
Hi ,
Do you intend to use remote node controller with router broadband modem or bridge broadband modem ?
JYL
using bridge broadband
J
