Remote Networking
Aruba
Avaya Wired Phone Not Connecting on RAP-2 eth1
I have a customer that is deploying RAP-2s to their users. The eth1 port has an Avaya 4600 phone connected to it; and a PC connected through the phone. On the customer’s LAN this works just fine. When plugged into a RAP-2; the PC can get an IP on the data network (Native) just fine; however the phone never seems to flip over to the voice VLAN as indicated by option 242 in DHCP; in fact we never see a DHCP request from the phone when doing packet captures. When connecting a switch between the RAP and the Avaya phone (switch is configured with trunk port to the RAP); the PC gets on the data VLAN and the phone gets on the voice VLAN; and all works just fine.
Does any one have any thoughts as to why this may work through the switch and not directly connected to the RAP? I am thinking of 802.1q is enabled on the phone.
eth1 Config:
wired-ap-enable
forward-mode tunnel
switchport mode trunk
switchport trunk native vlan 904 (data vlan)
switchport trunk allowed vlan 903-904
aaa profile is open and role allows all (opened up to try and get it working)
Thank you
AMFX | ACCX | ACDX | ACMX
Break out the hub....
I'm going to ask you to do this, because support is going to, as well. if you have a hub, break it out and place it between the Avaya phone and the RAP and sniff all the traffic.
Aruba
Re: Avaya Wired Phone Not Connecting on RAP-2 eth1
Hey Colin; thanks for the suggestion. Agreed; but we just couldn't find one when onsite that day. Figured I'd ask here to see if there was a known issue of some sort.
Short of anyone having seen this before, I'll see if they can dig up a hub.
We wound up giving up on the voice VLAN and just creating a failed auth role for the phones that include the ports needed for the phones to work. This has worked well for us.
Thank you!
Aruba
Thank you!
So you had a similar issue? Was it also Avaya phones on a RAP-2? Did you troubleshoot with support at all? I am going to be back working on this on Monday.
Sorry I forgot to set this to alert me of replies. I am not sure to be honest, I kind of inherited the controller from others and they claimed they couldn't get voice VLAN's to work so I went with the path I selected since it was easy to get working.
Did you get it working?
