Remote Networking
Bridge mode with 2SSID and 2 Vlan
I have question in RAP bridge mode. My customer would like have 2 ssid one is 'Guest',one is 'employee'. Each SSID will have own VLAN.
Based on this requirement, can will do it. AP i using is AP105
Contributor II
Re: Bridge mode with 2SSID and 2 Vlan
Yes, you can, yours will have a native VLAN that will be used for the AP to stablish connection with the controller. And each VLAN assigned to the SSID. So you have to configure the switch where you will plug the AP with a unttaged VLAN for the AP to stablish connection with the controller, and two VLAN tagged that have to match the VLAN configuration on each SSID.
Regards
