Remote Networking
Don't want VIA client to auto-start
Is it possible to set the VIA client so that it doesn't automatically launch on login? I'm just setting this up for users who will need access 1-3 times pre week from home or on the road. If they don't need access to the office network, I'd prefer not to have them automatically connect.
Thanks!
Re: Don't want VIA client to auto-start
You can remove VIA from the windows startup folder, that should prevent VIA from starting up.
Jerrod Howard
Sr. Techical Marketing Engineer
That's hilarious - I was looking for something more complicated, when it's actually that basic. Thanks.
I believe there is a checkbox somewhere in the VIA configuration that controls "auto launch."
There is an option to enable or disable 'Client Auto-Login' under the 'VIA connection profile' -> VIA Controllers. There are other available options that can be enable/disable at this level.
Cheers,
** M.T.
Aruba
Auto Login...
Cheers,
** M.T.
Keep in mind that the "auto login' option controls whether the VIA client will auto connect/login to the network, and run through its TRUSTED/UNTRUSTED network logic. It does not control if the client will auto-start when windows boots.
