Remote Networking
Extending Remote Network AP-70 ENET1
Gurus,
I would like to increase port density off of ENET1.
I would like to attach a cisco 3550 switch off of this interface.
My wired-ap-profile looks like this:
ap wired-ap-profile "RemoteOffice"
wired-ap-enable
switchport access vlan 708
trusted
Although the wired-ap-profile sets ENET1 as an access switcport, when I connect a cisco 3550 to it I still recieve 802.1q bpdus. This essentially blocks the port.
If I connect an un-managed switch such as a netgear... everything works as expected.
But I would like to connect a "real" switch to the ap-70... Has anyone run into this issue? Or know of a fix?
-a
Re: Extending Remote Network AP-70 ENET1
The only way I was able to fix this issue was to disable spanning tree on the cisco switch's vlan and connected ports.
interface fa0/1
switchport mode access
spanning-tree portfast
end
conf t
no spanning-tree vlan 70
end
... oh well.
-a
