Remote Networking
Guest WLAN - Split Tunnel issue
Clients under Guest WLAN with Captive Portal authentication, could use Split Tunnel rule ?
Instructions for Split Tunnel Captive Portal
Instructions for Split Tunnel Captive Portal from the RN user guide attached.
Contributor II
ST CP Guide - Thanks...
Thanks Colin.
