IP Pool Keeping Address
Hi All,
I am setting up the IPSec VPN, I have put a IP Address Pool in place but it seems it keeps the address in use even though the client has disconnected, which is causing me a head ache.
Known issue or is there a setting I got missing.
Re: IP Pool Keeping Address
It should release the address. How long do you observe?
Colin Joseph
Aruba Customer Engineering
Depends I have disconnect, and it doesn't release and I also wait the hour and the same but gave the controller a boot to see what happens.
How many addresses do you have in the pool?
Colin Joseph
There are two bugs related to this that was fixed in 6.1.1.0:
41299, 45362
An IP pool leak that was preventing users from connecting using L2TP VPN has been fixed.
Colin Joseph
