Contributor II
IP TV Multicast
Could someone help me with below scenario.
We use 6000 series controllers in main & remote sites which are reachable through WAN link. Can I extend the IP TV multicast stream in one site to the other site somehow, or VLAN used for IP TV can be extended to other site?.
Mathew
Re: IP TV Multicast
Is this wired or wireless multicast?
Contributor II
Re: IP TV Multicast
It's wired in one site, I want to take that Vlan to the other site using Aruba.
Contributor II
Re: IP TV Multicast
Its wired, however I want to show this in another site.
Re: IP TV Multicast
You can use the 2nd port on an AP125, AP135 AP70 or RAP2 access point to send that wired traffic back to the controller in the datacenter.
Contributor II
IPTV multicast
Hi Joseph,
Could you explain more. The second port of the AP located in which site.
Re: IP TV Multicast
I am sorry. I misunderstood you. You want to extend a VLAN between controllers for IP Multicast. The best way to do this is a site to site GRE tunnel.
Please see the article here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=1485
