Remote Networking
Frequent Contributor I
IPSec UP (Tunnels) does not show
Hi All,
We are using 3.3.2.18-rn-3.1.3.
When we connect RAP-2/5 and even AP61 as RAP, the IPSec UP columns do not show the numbers of RAP devices.
Is it normal?
The SSIDs are running split tunnel. (There's some typo errors on the user guides on split tunnel)
Michael
Which firmware version can we use?
IPSec Tunnels
Hi All,
Is it normal?
Michael
The Monitoring Screen should reflect a 1 for every RAP device that is currently connected to the controller. If not, please upgrade to the latest code and check it again. The latest code is in 3.3.2.24-rn-3.1.8.
