JYL
MDAC on Split Tunnel
Quick question to all experts
Does MDAC support split Tunnel or only Tunnel mode
Joey
Re: MDAC on Split Tunnel
MDAC has a number of components and they all work on tunnel today. You might want to contact your Aruba sales team on what components will be supported via split tunnel.
JYL
Thanks Joseph, at this writing the reason I ask here is because they are not sure if MDAC supports split-tunnel. Im hoping to get an answer from all experts here.
thanks
joey
The role derivation by dhcp option does not work on split tunnel as of today.
