Remote Networking
MVP
Possible to connect RAP through different port?
We need to provision remote AP's with a customer that only has 1 external ip address on which port udp4500 is already in use.
Is there a way to have the RAP connect to a different port so we can forward that to the controllers internal ip on port 4500?
Koen (ACMX #351 | ACDX #547 | ACCP)
Re: Possible to connect RAP through different port?
Not at this time.
