Remote Networking
Provision RAP 2WG on Campus (ARUBA OS5.0)
I have followed the steps for Remote Access Points (Chapter 7) via the ArubaOs5.0 User Guide.
I have seen the video on how to Provision from home, but I would like to provision on Campus before the AP is delivered.
-The AP's MAc address had been added to the white list.
- The AP has been plugged directly into the Controller on both e0 and e1, however, it is still not visible, so I can provision it (IKE pre shared Key)
I can tell you that after adding the default VPN Authentication profile (step #1 and #2 page 170), I was not able nor did I see any way to add a Default Role.
I tried a new AP and the provisioning...
I tried a new AP and the provising worked fine. Now to test it out.
I will reset the old to factory.
The VPN Authentication defult role configuration is still a mystery (Page 170 Step #3 of the OS5.0 guide)
