Remote Networking
Provisioning RAP on Aruba 200 running 5.0.2.1?
My 200 is licensed for RAP's but when I go into the AP provisioning page there is no option to select remote ap. Any thoughts?
Clear Browser Cache
If you upgraded the 200 from 3.x, please clear your browser cache first so that everything renders properly. Beyond that, you should be able to provision, APs using an IKE preshared key, username and password, but you should NOT be able to use cert provisioning, or put mac addresses in the RAP whitelist. This is because the legacy controllers (200, 800, 2400, Sup-1, Sup-2) do not support cert-based provsioning or the RAP whitelist.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Re: Provisioning RAP on Aruba 200 running 5.0.2.1?
Thanks Colin! The browser cache was my problem.
