Contributor I
RAP-5WN Max Devices
I have searched and searched and I cannot seem to find the answer to this. I would think that it would have been either in the spec sheet or in the install guide, but didn't find it in either....
Anyone know how many devices can be connected to a RAP-5WN both wirelessly as well as through the wired ports? I have a customer that wants to connect a total of 8 devices and is wondering if it will work before he deploys.
Thanks all
Jeremy R. Wirtz
WLAN Systems Engineer
Re: RAP-5WN Max Devices
8 is fine. It has a built in 802.11n radio. The main issue is usually the speed of your broadband uplink. Can it serve that many clients?
Colin Joseph
Aruba Customer Engineering
