Occasional Contributor I
RAP AP-70 Performance
Any performance numbers associated with using a AP-70 ?
Seeing were crossing an ISP & IPSEC is tunneling traffic , what are expected performance numbers ?
Are we running in hw or sw ?:
:confused:
Re: RAP AP-70 Performance
The AP70 is only rated for 5megs of traffic, since it is done in software. If you want performance, you should be deploying the RAP5WN, which is capable of 90 megs of encrypted throughput.
Thanks, where can we find throughput/performance numbers for the NEW RAP devices ?
I have not seen any numbers. From my personal experience, the rap2 is on par with the ap70 and the rap5 performs like mentioned.
