RAP and Sprint U300
Has anyone gotten a Sprint U300 to work on a RAP-5WN? My provisioning profile is configured for device type of "option" and device identifier as "0x16d86002" but no luck. I confirmed the device is in "modem-only" mode and it works just fine on my laptop.
Re: RAP and Sprint U300
You should only need type "Option" to make it work. Unfortunately, that will only dial the 3G side of the modem.
Thanks Colin. I'll try that tomorrow.
No joy. I had this card working in the RN train, but no go in 5.0 or other software I'm testing. Odd.
Please open a case, so it can get looked at.
Please try the following:
usb_type=option(2)
usb_dev=0x16d86008
usb_tty=ttyUSB1
