Remote Networking
RAP and wired-port dot1x with Layer 2 switch
So according to the VRD, a Layer 2 switch should not be in between the clients and RAP if dot1x authentication is used.
So what to do if there are more wired clients than ports on the RAP?
Any ideas?
Thanks :rolleyes:
ACCP, ACCX #817, ACMP, ACMX #294
Re: RAP and wired-port dot1x with Layer 2 switch
The problem is that the first switch to see an EAPol or 802.1x frame either has to handle it or drop it. Your only option may be to find a switch that can be configured with 802.1x passthrough support or put a hub out there...
What about plugging another RAP into it, will that work? Probably not the most economical usage of a RAP though.
Not supported.....:(
Contributor I
If the Layer2 switch supports 802.1x auth, could it be configured to perform the "STOP, Who goes there!?" and authenticate against the same back-end system as the controller?
Most switches authenticate directly to a radius server for that function, and you cannot point that to a controller. If you could configure a switch like that, you would lose policy-based enforcement. Aruba's New Corvina switch provides this functionality, however.
