Remote Networking
Contributor II
RAP bridge mode access from LAN
Hello
I've deployed AP in RAP mode with AOS 5.0.3. I 've a SSID deployed on bridge mode with VLAN tagging. From the wireless side I can access any service on the wired side, but from the wired side i can only ping the wireless clients.
The role asigned to the users is allowall, so the firewall it's discarded.
Also on the AP profile i've enabled local network acess but withour any luck.
Any advice?
Regards
Contributor II
Re: RAP bridge mode access from LAN
Sorry already answer ap-uplink-acl
