Remote Networking
RAP whitelist export and import
Is there a procedure that will allow the exporting of a RAP whitelist from one controller and then subsequent import into another?
Re: RAP whitelist export and import
Yes. The RAP whitelist is just a table on the local-userdb. The only issue is that guest users and local database users are ALSO part of that database, so if you export the local-userdb and import it onto another controller you will effectively replace the whitelist, guest user database and the local user database on that new controller, so caution.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Got it, thanks Colin.
