Remote Networking
Frequent Contributor II
RAP2 connection reliability
My boss likes to turn off his RAP2 at home when he's not using it. It seems that when he does this, it's very hit and miss whether the RAP will establish a tunnel when it's turned back on.
Are there any known issues with repeatedly turning the RAP on and off, for example let's say 3 times in the space of 4 hours ?
How can I debug why the RAP is not establishing a connection to the controller ?
We are running code 6.1.2.0
Lee
Re: RAP2 connection reliability
You could use "show datapath session table | include 4500" on the controller to see when the RAP5 first initiates IPSEC traffic. You can then use "show crypto ipsec sa" to see when it makes the security association. The rap2 is a low-powered device and take about 3 minutes to come up every time, so that needs to understood.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Thanks for your response Joseph,
Unfortunately, I'm in the UK, and my boss is in the US, I'd rather not have him phoning me in the middle of the night when he can't connect :)
Hence, I'd like to set some debugs up on the controllers to log his connection attempts and try to ascertain what's happening.
I've setup ap-debug logging for his RAP's MAC address, is there any other debugging I should be doing to assist with troubleshooting this.
Lee
Lee
Unfortunately, until the access point actually makes the connection, it cannot send any logs. The two commands are useful only in realtime. Alternatively, you can use the following commands to view to ike setup of that AP:
config t
logging level debugging security subcat ike
then do:
show log security 50
or just send the logs to an external device so that you can see what happens when he tries to connect.
