RAP5 Static IP
Hi all,
I have looked and not found a full answer I have a RAP5 needs to be manual IP Address. Tried accessing it on Port 1 and Port 0 to configure it and no joy.
Its running OS 5.0 from Previous use. Does any one know any way of doing this.
Re: RAP5 Static IP
When you Zero-touch provision a RAP it is a under a tab here:
Alternatively, when it connects to the controller and you provision it that way, there are fields to give it a static ip address.
Colin Joseph
Aruba Customer Engineering
