Remote Networking
Contributor I
RAP5-WN Remote Mesh Portal
I'm trying to deploy a RAP5-WN as a Remote Mesh Portal in ArubaOS 5.0.0.1.
It shows up as a portal, correct band and so on.
Problem is when I try to connect an AP61 as Mesh Point to this RAP5.
Just doesn't come up. I read the manual, added the Mesh Private VLAN to the profile. Added DHCP server config in the RAP5, added a Virtual AP with the Mesh Private VLAN and forward mode split tunnel. Lots of extra config for the remote mesh portal!
If i connect my console to AP61, this is what I can see;
AP rebooted Fri Dec 31 16:10:54 PST 1999; Mesh link could not be sustained for 15 minutes.
shutting down watchdog process (nanny wError removing br0 from bridge vlan 5
Christian Nilsson, Network Services
ACMA, ACMP, AWMP, Aruba Instructor, ACMX #159
Easiest Way
The best way to set this up is with the remote mesh portal wizard that is under the "AP Wizard" under configuration in ArubaOS 5.0. Give it a try...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Please try pure mesh network setup first
Please ignore "error removing br0 from bridge vlan xyz". That should not cause any issues.
I think the real issue is "mesh link not staying up for longer duration". In such case, I will first configure pure mesh network to see everything works fine and then convert it to Remote mesh network.
Contributor I
Re: RAP5-WN Remote Mesh Portal
I will try the wizard and see what comes out of that!
