Remote Networking
Occasional Contributor I
RAP5 Wireless LED not working in Backup mode.
I'm running on my controller.
When my RAP5wn loses connection to the controller the 2.4ghz LED goes out even though the AP is advertising my backup SSID's. I'm able to connect and use the SSID's.
Is it supposed to do that? I found it confusing and for quite a while I thought the wireless backup SSID's were not working.
Re: RAP5 Wireless LED not working in Backup mode.
Starting in 6.x that behavior changed to show the LED, whenever an SSID is broadcasted. In 5.x, it only shows when the AP is connected to the controller AND the SSID is broadcasted.
Colin Joseph
Aruba Customer Engineering
