RAP5 & USB modem
trying to get a USB modem to work thru a RAP5.
Got an USB modem (Provider: ICE) and have got this settings, but no go...
usb_dev=0x16d86803
usb_type=1 (or airprime in cli)
usb_user=cdma
usb_passwd=cdma
Also at the controller GUI, AP/USB settings, after save/apply. They do not appear, like we didn’t set it?
Have done the changes/settings in cli, that worked fine. But still no network thru the USB ICE modem.
Controller sw ver: 6.1.1
Anny suggestions?
Rdg.
Petter
Re: RAP5 & USB modem
What is the manufacturer and model of the usb modem?
It`s Ice.net D50 USB Modem.
http://kundeservice.ice.no/Portals/0/Guides-d50/D-50_User_Manual.pdf
We got a link regarding this issue that you have made earlier.
Going to try this upgrading of the backup partition at the RAP
http://airheads.arubanetworks.com/vBulletin/showthread.php?t=2151&highlight=backup+image
I`ll get back how it went...
rdg
Petter
