Remote Networking
Contributor II
RAP5WN refuses to go to 'a'
AP is getting the command from the ap group to use the A radio but will not switch. It is still using the 2.4GHz band. OS is 6.1.2.3 and controller is a 620. Everything works, it just wont switch to A.
Any idea? VAP's are set to use any band.....
Configuration for AP name "BH-RAP5WN" AP group "RAP"
Parameter 802.11g 802.11a Source
LMS IP x.x.x.x x.x.x.x ap system-profile "APSysProf-5WN"
LMS IPv6 N/A N/A ap system-profile "APSysProf-5WN"
Backup LMS IP N/A N/A ap system-profile "APSysProf-5WN"
Backup LMS IPv6 N/A N/A ap system-profile "APSysProf-5WN"
LMS Preemption Enabled Enabled ap system-profile "APSysProf-5WN"
LMS Hold-down Period 600 sec 600 sec ap system-profile "APSysProf-5WN"
Number of IPSEC retries 360 360 ap system-profile "APSysProf-5WN"
LED operating mode (11n APs only) normal normal ap system-profile "APSysProf-5WN"
RF Band a a ap system-profile "APSysProf-5WN"
Double Encrypt Disabled Disabled ap system-profile "APSysProf-5WN"
Root AP Disabled Disabled ap system-profile "APSysProf-5WN"
Native VLAN ID 1 1 ap system-profile "APSysProf-5WN"
Re: RAP5WN refuses to go to 'a'
I don't think the 5WN RAPs have a .A radio in them. Mine show .B, .G, and .N only in Airwave.
Under your virtual AP for your wireless network, what is the "allowed band"? It should be either set to ALL or A for it to work. The other thing is the RF band parameter in the AP system profile in the AP group, which it looks like you have changed, already.
Contributor II
The VAPs that are assigned to the ap-group are set to 'all'
I'll call TAC.
b
Type "show ap bss-table" to see what is being broadcasted on what band for that AP.
Contributor II
i have the same issue with te RAP5WN, allowd band "A" but only the 2.4ghz led is green, let me know how you fix it please.
It is not the allowed band parameter, it is the "RF band" parameter in the AP system profile that determines what band a single radio, dual band device broadcasts on.
Contributor II
I do have the RF Band parameter set to 'A' as referenced above in my ap system profile. I haven't called TAC because this was just a 'lab' setup and not a customer issue. I'll upgrade to 6124 and see what happens.
That should work regardless of code. You should not have to upgrade. It should be just a configuration issue. You should open a TAC case.
Yeah, that should have switched the RAP5WN over to 5Ghz, I do the same thing for an AP-61 in a room where 2.4Ghz is not needed.
Zach
Zach Jennings
