I might be trying something that the RAP-2WG was never intended to do, the unit come up ok provisions fine, and accepts clients but eth1 goes away. I thought that after the unit completes its IPsec tunnel that a cable attached device would also be able to use the tunnel. After I set the address of the master controller the wireless side activated with all that functions, but the Ethernet side that was used in the initial setup stops (losing its IP address). What am i doing wrong or?
Re: Rap-2wg
John, check the port profile assigned to eth1 via the AP Group that the RAP is in. The profile will determine how the port behaves after the tunnel is up.
