Rap -2wg
Hi Guys.
I am new to Aruba.We recently purchased a RAP-2WG wireless Access point and Iam unable to configure it CAN anyone help me out as its critical...:o
Re: Rap -2wg
Hi Patrick,
That's not a small request:) The user guide on the support site will have that information. You should also take a look at the VBN VRD available on the public site. That will give you the background information you need to get going: http://www.arubanetworks.com/pdf/technology/VBN_VRD.pdf
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Re: Rap -2wg
The user guide tells me to connect E0 to the modem and the other E1 to the pc.. U will be getting the ip ...all this is working for me also..But when i specify the Ip for the device ..I am getting an "Received error RC_ERROR_IKEP1. Trying (4/4)" and it restarts.
Re: Rap -2wg
You need to tell us a lot more about what you're trying to do. Controller model number and software version would be helpful. Also, did you add the RAPs MAC address to the whitelist?
-awl
Andy Logan, ACDX
Aruba Networks
