Rap-5wn
Hi Guys,
Been given a RAP5-WN to setup for my boss, its all working fine, but I am only getting 2.4GHZ light come on, is this a signal band device?
I been looking and all I keep finding is it supports A,G,N but nothing saying Singal or Dual, if it is a dual how do I enable the 5Ghz band.
Regards
Luke
Re: Rap-5wn
The RAP5 only supports 2.4 OR 5ghz. If you want to change the radio to 5ghz, instead, the "Band" parameter in the AP System profile in that AP-Group is what you would have to change.
Re: Rap-5wn
Thought that was the case thanks very much mate.
