Rap2 dhcp
In short, my issue is this: Any wireless device that connects to my RAP2's can get an address no problem. If I try to hook a PC into ETH1 it will not pull an address. I have created a profile that does not shutdown the port and has the same settings as the wireless as far as VLAN and tunneling. I can't figure out whats going on. Thanks in advance!
Aruba
Rap2 dhcp
I would sniff the port with Wire Shark and see if you see any traffic
there at all.
