Rap5 and 4g usb
Has anyone got a 4G USB to work on a RAP5? If so, would you mind sharing which 4G USB, and how you got it to work?
** M.T.
Re: Rap5 and 4g usb
It's not supported yet, MT.
Re: Rap5 and 4g usb
Would it work if I've tried?? :D
Re: Rap5 and 4g usb
Unfortunately not, very different from 3G.
-joshua
Re: Rap5 and 4g usb
4g uses a different connection method than 3g and roaming between 4g and 3g networks and back is still not very good in preliminary testing. The technology is very new and still needs much testing.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Regular Contributor II
Re: Rap5 and 4g usb
Is this still the case?
I'm not able to search for 4g as the term is too short for the forum search engine.....but this is the only thread that pops up when using our popular search engine friend!
Re: Rap5 and 4g usb
Please contact your local Aruba sales team for more information on this.
Re: Rap5 and 4g usb
Is the problem with 4G strictly related to drivers and other issues?
What if you had a 4G device that also had an Ethernet port for connecting a single device (intended for a single PC)?
Would there be anything that would prevent a RAP5, or possibly even a 600 series controller, from using the connection the same as a typical broadband connection?
Re: Rap5 and 4g usb
It's a driver issue. If you had a 4G device that provides an ethernet handoff, the RAP would not be involved in the 4G connection, so it's no issue to use one of those devices.
