Remote MESH
Hi
I need to design a new solution for a remote mesh. I have a 620 controller on main site and on the remote site I would like to set a RAP5-WN straight into the internet connection as a Remote Mesh Portal and an AP-105 as a Mesh Point.
Do any have a full detailed design for such a scenario?
I got the mesh up and running locally. I got the RAP up and running. But converting to Remote Mesh Portal it fails.
I hope that someone in here have more experience than me with the setup and can be kind to advice me
Re: Remote MESH
Please try the very excellent description by Viregg here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=2824
Re: Remote MESH
So I have. I followed it from the very first to the very last, but still no luck. The Mesh Point will not come up. Even though the portal is Remote it should still connect when connected locally on controller?
Re: Remote MESH
If you have the RAP5WN connected locally to a controller, do not configure it as a remote mesh portal. Just configure it as a regular mesh portal.
Re: Remote MESH
It is connected locally now, but it will be sent to the remote office as a Remote Mesh.
The Mesh Point is up, but I can't connect to the SSID..
Re: Remote MESH
Can you initiate user debugging (config t logging level debug user) to see what is going on with the user? (show log user debug 50)
Re: Remote MESH
I got the Remote Mesh up and running. Had the SSID in split-tunneling and found that this is not supported unfortunately.
However, I'm setting up a RAP5 in brigde mode instead. But when I assign ip addresses to the clients from the RAP they can't get proper communication.
What should I do in a case where I have no dhcp server on site?
