Remote Networking
Remote Office AP Deployment
Good Morning
Can anyone help with some advice on adding AP ( to a remote office where a router is in the middle? Do we need to do anything special on the controller (3000) or router to allow those APs to communicate witht eh controller.
Thanks in advance
Re: Remote Office AP Deployment
Hi Ed,
It depends on what you are trying to accomplish and what your network looks like. If this is over the internet we would suggest a remote access point (RAP) mode of operation, which requires a license on the controller. You will also need to provision the AP as a RAP, either manually or through self provisioning on the new RAP series.
Here is some more information on the solution:
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
