Remote Networking
Frequent Contributor I
Something to share on split tunnelling...
Hi all,
I've just tested split tunnel on RAP-2...
Anyone noticed that the split tunnel takes a while, after the SSID comes up, to work normally?
Michael
Re: Something to share on split tunnelling...
Michael - No, personally I have never seen that behavior. Are you running the latest code...or at least very close to the latest?
Could this perhaps be some kind of DNS issue? Perhaps your client is cycling through DNS servers and the first few aren't accessible for some reason? Just throwing out ideas...
Can you give us some more info on the lag time and what isn't working? Are you saying it isn't routing out the traffic? If so, what is the delay and what type of traffic? Is it all destinations?
I've never seen it as an issue, but I've never done anything to measure it either, once I get associated the traffic seems to work fine.
-awl
Andy Logan, ACDX
Director, Strategic Account Solutions
Aruba Networks
Hi all,
It is the boot time timing issue.
SSIDs will be up in less than 2 mins.
Cheers.
Michael
