Remote Networking
Step by step guide for Setting up RAP in OS 5.0.2
Hi Everyone ,
1.Can anyone guide me or has a step by step guide for enabling RAP in my controller with OS 5.0.2
I already have a public ip address translated to the controller with UDP port 4500 open
2. Is there a software Vpn client which i can use instead of access points.
Re: Step by step guide for Setting up RAP in OS 5.0.2
In the ArubaOS 5.0 user guide there is a chapter on remote access points that tell you how to set this up. You can use a sofware lt2p or pptp vpn client or the Aruba's own VIA client. How to connect a software client is discussed in the "Virtual Private Networks" chapter. How to configure Aruba's VIA VPN client is discussed in the "Virtual Internet Access" chapter.
Aruba
1. The Remote Access point (RAP) functionality is outlined quite well
in Chapter 7 of the AOS version 5.0 User Guide (UG) document.
2. We (Aruba) do make a software client called VIA. I would use that
client in parallel to the Remote Access Points (RAPs) rather than a
replacement as such. There are many reasons for this...most of which
you can review with your local SE.
