Remote Networking
Contributor I
Unable to connect clients RAP5
I've this scenario... We´re using a 3200 un the HQ with AP105, but we also have RAP5 in Branch Office, this RAP5 are configured in bridge mode authenticated via Radius same as in HQ, but when the clients connect first to the RAP5 and then they go back to the HQ or viceversa they are unable to connect (both HQ and Branch have the same SSID).
Any idea ??
thanks
Re: Unable to connect clients RAP5
What types of wireless clients?
What types of encryption?
We have users that do this all day, every day... Did this ever work?
Did you try to enable client debugging to see what is the issue?
In addition to what Colin asked, are the wireless clients configured to use DHCP for IP addresses or are they set statically?
Charlie Clemmer
Aruba Customer Engineering
Contributor I
Laptop clients.
The Encyption is WPA/TKIP
Contributor I
They are using local DHCP
Contributor I
Ok. here is an update.
I need to delete the user via cli command "aaa user delete "
When I do that the users are able to connect..
Is there something to do about this?
Thanks for your responses
Are the users still in the user table when they roam from one to the other? Did you modify the default user idle timeout value? Are the RAPs within earshot of the regular Campus APs?
Contributor I
How Do I modify the default user timeout?
It is under Configuration> Security> Authentication> Advanced Tab.
It is the user idle timeout that says how long a user will stay in the table after not passing traffic. By default it is 5 minutes or 300 seconds. Please record what it is, and change it to 300 seconds and see if you are having the same issues.
Contributor I
I´d change the default values , and the clients still have the same issue.. any other idea?
