Frequent Contributor II
VIA Client Error Codes?
I'm setting up VIA and receive this error code:
error-8949 "failure to establish secure connection"
The message is not very useful in helping to figure out what the issue is.
Has anyone run in to this error code? What did you do to fix it?
Or does anyone have a list of error codes with possible fixes for each error code?
David Dipert
Re: VIA Client Error Codes?
For me, I found that having multiple IPSEC PSK's for IP address 0.0.0.0 would not allow the VIA client to connect.
The web interface / VPN tab only showed one, but cli "show run | include crypto" will display all.
Anyone experience this Err 12007?
What is the resolution or is there a reference link for this error?
"If there's a will, there's a way."
