VIA SSL Fallback option
Hi All,
We have VIA working all nicely but have noticed that it doesn't connect from some locations where UDP 4500 is not allowed outbound. I've read in the release notes that there's an SSL fallback option but can't for the life of me see where this option is set on the controller!
James
Cheers
James
-------------------@whereisjrw-------------------
------------------------blog-------------------------
Re: VIA SSL Fallback option
Hi All,
James
(3600.arubanetworks.com) (config) #aaa authentication via global-config
(3600s.arubanetworks.com) (VIA Global Configuration) #?
no Delete Command
ssl-fallback-enable Enable or disable VIA SSL Fallback
Colin Joseph
Aruba Customer Engineering
Thanks. I'll give it a go.
What's your experience of it? Asking as it says the feature is still in beta..
Cheers
James
It works, but only for Windows Clients, for now. There is still a decent amount of testing that needs to be done to ensure it loses the "Beta" tag. Fine for the lab, certainly.
Colin Joseph
Ok thanks for your help.
Cheers
James
