Occasional Contributor I
VIA XAuth failure
Anyone seen a VIA user failed authentication with an message of "IKE XAuth failed for "?
User was able to authenticate, download the VIA client and, successfully pull the VIA_0/{Controller} Connection Profile. Subsequent connections fail.
Randy
Re: VIA XAuth failure
you need to set a "dummy" IKE shared secret in your vpn settings on the controller.
Configuration> Advanced> VPN Services> IKE shared Secret. Click on add, to add any IKE shared secret.
Pre Shared secret is already set.
(WDC-620-3BLAB-01) # show running-config | incl ike
Building Configuration...
netservice svc-ike udp 500
user any svc-ike permit
ike authentication PRE-SHARE ******
ikev2-policy "10004"
ikev2auth eap-mschapv2
Randy
Moderator
This is probably worth opening a TAC case. I would suspect it's just a configuration error, but we really need to see the entire config file to be sure. I suspect you probably don't want to post the entire thing on a public forum. :)
Also, VIA can generate logs with the "Send logs" button. This will be very useful in troubleshooting problems.
Jon Green, ACMX, CISSP
Security Guy
Agreed and will do...Thank you
