VIA client + Aircard
Since this seems to be VIA question day...
My VIA clients seem to work beautifully on wired and .11 wireless. On "aircards", not so much.
For example - I have an AT&T USBConnect Mercury USB GSM wireless. I can connect and browse the web. I can download and install the VIA client. When I try to connect to through the client, here's the diagnostics:
Remote server access ... Not Reachable
Remote server access ... OK
Network Interface ... Not Ready
Client encountered an internal error
On the Connection Details tab, it's an error 12031 - "Client encountered an internal error"
Anyone else using GSM cards successfully? What models?
Open a case
Jim,
Please open a case, so we can separate or address the card issue from the Via issue, or the combination of both.
