Frequent Contributor I
VIA help
Hi all,
Understand VIA is out for a while.
Can I check on the following, whether:
1. there will be a VIA Wizard?
2. there is a sample configuration for demo purposes too customer?
3. there will be a chance A200 or A800 supports VIA (maybe just a particular version?)
Thanks.
Michael
Re: VIA help
1. None Planned.
2. In the ArubaOS 6.0 user guide there is a step-by-step document on how to set this up, complete with explanations
3. Legacy Controllers (200, 800, 2400, Sup-1 and Sup-2) will not be supporting VIA.
